spheres layout
hayden2004
spheres layout
Unread post by hayden2004 »
please advise which sphere is which under the bonnet on a xantia hydroactive 2.0 8v auto 1995
uhn113x
x 3
Unread post by uhn113x »
There should be at least three, surely?
hayden2004
yes at the front on the engine there is two one with a electro vavle fitted on the block nearby
alexx
Unread post by alexx »
The one behind the radiator is HA front middle sphere. It's mounted on the stifness regulator (you will see two 10 mm pipes, connected to corner suspension cylinders, and some wire, leading to hydractive ECU).
Other, mounted on the pressure regulator, which is on the engine, is accumulator sphere.
hayden2004
thanks for that must be electro valve thats duff
Kowalski
Unread post by Kowalski »
Don't forget the two on top of the suspension turrets...
