C5 2009 lcd display panel
crazyfach
Can anyone help please , has anyone changed the LCD display panel , mine has bled, how do you get the dash trim off, thanks
vborovic
- Locked user account
- x 40
Re: C5 2009 lcd display panel
You need to pull the lower trim plastic off (unhook it), you'll have 3 trox screws to unscrew, and pull out the entire dash screen element (watch out for the hazard lights cable, it is attached to the switch)
crazyfach
Thanks i'll let you know how i get on.
- x 2008
Mine starts to fail when hot....wonder if it is a "problem"
vborovic
- x 40
Remove the quotes ...
... maybe a loose connection that occurs when the heat "bends" some of the surrounding material (don't expect the screen could actually overheat) ... the challenge would be to find the location of this glitch ... I'd start with the cables and pins on them ... both ends ...
SaabC5
Mine does exactly the same. If you put your hand into the little storage bin on the dash it gets red hot so i suspect thats why. If i put the climate on 16 it usually gets better after about 10 minutes.Stickyfinger wrote:Mine starts to fail when hot....wonder if it is a "problem"
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
vborovic
- x 40
@ Saab - You have the simple orange matrix display, no navigation, right?
- x 2008
@ Stickyfinger....I do,, SAABs is doing what mine does....
I had AirCon on today, back normal display after 2/5 mins after first started (Car was HOT inside)
SaabC5
Correct.vborovic wrote:@ Saab - You have the simple orange matrix display, no navigation, right?
vborovic
- x 40
DIY project - 12V PC cooler fan, there are even double ones, quite silent at that, put it on the rear of the screen, and voila ... insta-cool ... maybe the screen color will change from orange to blue ...
dnsey
- x 19
It might not be a fault as such - LCDs have quite a limited operating temperature range, so it might just be doing what comes naturally if gets very hot.
- x 2008
Which makes it a "design fault"....can't be, its made like a German car
