Need help with weight
Paulwhalley
As Dvla changed the rules for towing I can not go over the combined weight of 3.5 tons. can any one tell me the weight or where to find it on my 54 reg Peugeot boxer swb is as we are looking to buy a caravan and don't want to risk being over weight so far from home
Sent from my iPhone using Tapatalk
MikeT
- x 232
Re: Need help with weight
Quick google got me these - any good?
http://vanleasingmadesimple.com/van-lea ... -unbraked/" onclick="window.open(this.href);return false;
http://www.anchorvans.co.uk/specificati ... eot/boxer/" onclick="window.open(this.href);return false;
Paulwhalley
Thanks they look to be newer models or have the 2.2 engine don't no if it's any help but on the log booki think it says Peugeot boxer 290
DickieG
- Monaco's youngest playboy
- x 38
Have you looked in the handbook? They normally give dimensions/weights etc.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Paulwhalley
Didn't get a handbook with it unfortunately
- x 2000
http://www.helpfindmea.co.uk/vans/specs ... -5628.aspx" onclick="window.open(this.href);return false;
Deanxm
- x 87
So far as I'm aware, if you run over 3.5t gtw regardless and you are operating for hire or reward (carriage of goods) then you must operate under EU drivers hours or domestic hours rules and so must keep a record of drivers hours is fit a tacho and apply for the relevant operators license, its never been any different.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Paulwhalley
Thanks good lot of information there should I presume my 2.0l is the same weight as the 2.2 ? I can't see that there will be that much difference
MikeT
- x 232
What about this one?
http://www.parkers.co.uk/vans/reviews/p ... ical-data/" onclick="window.open(this.href);return false;
SWB 2.0HDi 290
2850 mm
2150 mm
2024 mm
1145 kg
SWB 2.2HDi 290
2850 mm
2150 mm
2024 mm
1075 kg
SWB 2.0HDi 290
2850 mm
2150 mm
2024 mm
1145 kg
SWB 2.2HDi 290
2850 mm
2150 mm
2024 mm
1075 kg
Paulwhalley
Deanxm wrote:So far as I'm aware, if you run over 3.5t gtw regardless and you are operating for hire or reward (carriage of goods) then you must operate under EU drivers hours or domestic hours rules and so must keep a record of drivers hours is fit a tacho and apply for the relevant operators license, its never been any different.
D
As I passed my test after the first law came in I can not be over the weight of 3.5t under any circumstance ( which the Dvla told me today)so no need for tacho if I want to be able to pull over the 3.5t threshold I then need to do a trailer test
Deanxm
- x 87
Yes on a B license you are limited to 3.5t gtw Max and 750kg mam trailer Max so you can drive the combination so long as you don't exceed the 3.5t gtw threshold, you may struggle to find a caravan that will be under 750kg with all the gear on board though.
D
D
XM Prestige PRV6 92
Paulwhalley
What's the mam?Deanxm wrote:Yes on a B license you are limited to 3.5t gtw Max and 750kg mam trailer Max so you can drive the combination so long as you don't exceed the 3.5t gtw threshold, you may struggle to find a caravan that will be under 750kg with all the gear on board though.
D
Deanxm
- x 87
Sorry Max authorised mass, like gvw but for trailers
D
D
XM Prestige PRV6 92
Paulwhalley
My head is baffled now to many weights about
DickieG
- x 38
Have you looked around the van for the plate displaying it's weight? It's normally located either under the bonnet or in/around the door footwells on commercial vehicles.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
