Good Afternoon Gents,
Sadly the Citroen failed the MOT with 'Nearside front parking brake recording little or no effect'
I've just had a quick look and when the handbrake is applied there is less movement on the nearside. Also with the handbrake off the handbrake caliper operates on the nearside suggesting a stiff cable?
I picked up the inner cable from GFS on the way home from the MOT, it is probably that I'll need the outer tube, where is the best place to buy one of those?
Any thoughts would be gratefully received?
Citroen C5 failure of handbrake on MOT.....
howiedean
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
- x 2008
Re: Citroen C5 failure of handbrake on MOT.....
As a rule of thumb, ALWAYs replace both, The corrosion inside the tube will cause the cable problem again quite quickly. Ask me how I know
howiedean
Thanks for the quick response. Where is the best place to get hold of the outer?Stickyfinger wrote:As a rule of thumb, ALWAYs replace both, The corrosion inside the tube will cause the cable problem again quite quickly. Ask me how I know
Howie
Dealer only I'm afraid but not terribly expensive.
howiedean
Thanks for that. One last question, I've disconnected the tube and cable from both ends however does it have to be removed from the front of the car?Gibbo2286 wrote:Dealer only I'm afraid but not terribly expensive.
I'm having a bit of trouble with the wheel locking bolt at the moment therefore I'm having to work with the front wheel on.
Regards,
Howie
- x 2008
A tip, before removing the tube, tape some string to it. Attach that to the new tube and use that as a guide to the path you replace it into and help you pull it back thru..a helper tugging it helps.
Yes it comes out to the front.howiedean wrote:Thanks for that. One last question, I've disconnected the tube and cable from both ends however does it have to be removed from the front of the car?Gibbo2286 wrote:Dealer only I'm afraid but not terribly expensive.
I'm having a bit of trouble with the wheel locking bolt at the moment therefore I'm having to work with the front wheel on.![]()
Regards,
howiedean
Thank you, will try this when I get the tube.Stickyfinger wrote:A tip, before removing the tube, tape some string to it. Attach that to the new tube and use that as a guide to the path you replace it into and help you pull it back thru..a helper tugging it helps.
Gibbo I'll hopefully get this sorted very soon......
Howie
howiedean
howiedean wrote:Thank you, will try this when I get the tube.Stickyfinger wrote:A tip, before removing the tube, tape some string to it. Attach that to the new tube and use that as a guide to the path you replace it into and help you pull it back thru..a helper tugging it helps.
MOT re-test pass this morning.
I had to take the car to a garage to get off the locking wheel nuts, I got them to do the handbrake at the same time.
Howie
