Hello
I need to change my discs and pads as there metal on metal now only thing is to take the disc of you need to remove the driveshaft lock nut but don't no what size it is and the other is the Allen bolt in the back of the calliper all the sizes I have don't fit so need to go buy new tomorrow as I'm due to go to Doncaster at 10am. It's a Peugeot boxer 54 reg.
hopefully some one on here has the information I need
Paul
Sent from my iPhone using Tapatalk
Desperately need some help
spider
- x 77
Re: Desperately need some help
Front calliper ?
The front caliper hex/allen bolts are (guess) 12 or 14 mm, I remember I had to buy two large keys for them as the standard set did not go that high. Do not buy "keys" buy something that will fit on a ratchet, 1/2 drive ideally.
I cannot recall having to take the driveshaft nut off though ? Are you sure its not just the calliper carriage and the disc screw holding it ?
I'm unsure if a special adaptor (in theory) is needed ot reset the front bearing play but this may be separate to the disc, but as I say I cannot remember (or envisage) you needing to undo the hub nut to get the brake disc off...
Andy.
Paulwhalley
I've got a 12&14 12 is to small and the 14 is to big unless there is a load of crap in there.
All the smaller cars/ vans I've had all had a grub screw holding the disc in place but not in this one the only thing I can see holding the disc on there is the driveshaft nut
I've done some googling and from what few articles I can find it appears it's a 41mm
