Xantia failed smoke test
lazza
Unread post by lazza »
HI
Just had my spanish MOT done. All was fine, but it failed its smoke test. Instead of 2m-1 of opacity it had 11.71m-1 of opacity (whatever that means) :?
I had been noticing black puffs of smoke from the exhaust the last year with rapid acceleration. It seemed particularly bad today so I wasnt surprised when it failed.
Could the forum give me some pointers on how to mitigate this without having to take it to a garage?
Cheers
Larry
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
x 3278
Re: Xantia failed smoke test
I would check the air filter first. If it is clogged you can get poor combustion. Something else you might want to try is to take the car for a nice long high speed drive. This can help to clear things out.
x 1238
Unread post by Peter.N. »
Yes, I always give mine a good thrashing on the way to the MOT because if its only been driven gently it can accumulate a lot of soot in the exhaust and this is what it will blow out on test.
x 1974
Unread post by Stickyfinger »
When did it last have a good service, eg, tested on a Lexia, fault codes read/checked, injectors checked, fuel filter, AirFilter...etc ?
chinkostu
x 30
Unread post by chinkostu »
Al, a 96 TD (like mine) won't show much on a lexia bar ABS really as they're pretty much all mechanical, no ECU so no check engine light just a crank sensor for the tacho and sensors to kick the fans in. Might be able to read temps and revs but that all depends on if the dash outputs it to the socket aswell!
as said, check filters. They're cheap and easy to replace. Also check you've not got any boost leaks as you'll get smoke from incomplete burn if theres a leak
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
superloopy
x 19
Unread post by superloopy »
Mine chucks out white smoke on startup ... ?
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
isisalar
x 3
Unread post by isisalar »
Removing the air filter completely for the re test will probably do the trick.
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
lazza
What's a boost leak?
electronmirror
x 30
Unread post by electronmirror »
When the turbo is blowing it produces a boost to the air supply into the inlet manifold. If you have any holes in the large diameter rubber pipe feeding the inlet manifold you will get 'boost leak'. The fuel pump won't know that and will deliver more fuel than can be burned completely hence incomplete combustion and black smoke.
Check that big pipe from the turbo outlet all the way to the inlet manifold.
Good luck
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
BX
x 19
Unread post by BX »
1 litre of Dipetane in the tank and a good hard drive to the test will sort it. Not sure of sterling prices but normally costs 12 to 15euro.
Edit: just noticed you are in Spain so euro prices.
chinkostu
x 30
Northerner wrote:Mine chucks out white smoke on startup ... ?
Glowplugs working? Does it smell of diesel?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
MikeT
x 232
Unread post by MikeT »
Mine smokes like a destroyer trying to hide itself and passes the emissions tests every year so yours must be really bad (or the tester chose the incorrect limits for your car) to fail by over 5x the limit? Are you sure it's black smoke and not blue?
I just noticed, you run veg oil - it should burn even cleaner.
I always present my car for it's MOT with new oil and filters and, as others mentioned a good thrashing (or italian tune-up) to blow out the accumulated soot from the exhaust. If it still fails, you may need injectors cleaned/replaced or something more sinister is going on. You can de-tune the pump for less smoke (and therefore less power) but that would be a last resort imo.
The fuel pump enrichment relies on boost pressure so I can't see how a boost leak would cause overfuelling - happy to be shown wrong though.
chinkostu
x 30
MikeT wrote:Mine smokes like a destroyer trying to hide itself and passes the emissions tests every year so yours must be really bad (or the tester chose the incorrect limits for your car) to fail by over 5x the limit? Are you sure it's black smoke and not blue?
When i bought mine the pipe from the intercooler was off and the missus commented on the smoke!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
lazza
Yeah, i normally run on veggie oil and it smokes less, but for the test i fill up on normal diesel so they dont get funny. But it's definitely black smoke. Glow plugs are new and no it doesnt smell of diesel. It only happens when you really kick down on the pedal
So what from what you tell me, it could be:
1. A boost leak, I will check the turbo piping
2. Air filter, but i doubt it as it was changed not long ago
3. Injectors
AS I've never had problems on the emissions before I didnt know about giving it a thrashing beforehand. However, I'd like to find out it there is some underlying problem, cos I dont want to go back and it fails again- then I'll have to pay for another MOT and so it will go on.
I have also played around with the pump alot recently- could it be that it is injecting too much fuel??
MikeT
x 232
Depends what you played with exactly but Yep! Definitely could be.
Don't worry about thrashing these diesels. Firstly, they're diesel and built stronger than petrol engines. Secondly, the fuel pumps are so heavily governed, you're not really thrashing them at all. They could produce so much more power without worry but the resultant smoke (search youtube tractor-pulling) would make you the most hated motorist wherever you go.
