I have a 307 (53 plate) and when i start the car up, the ABS is fully on, which means every time i put my foot on the brake the ABs engages and gives that lovely crunchy poppy noise (like you have stamped on the brakes on a car fitted with ABS). After about 2 mins it reports an ABs fault and turns the ABS off. drives lovely after that.
Does anyone know where i can get a copy of the Peugeot Planet software for my laptop? I already have a compatible cable. I want to be able to diagnose where the issue lays. Thanks in advance.
307 ABS issue
- x 1995
Re: 307 ABS issue
Correct me and shoot me down, but I think you need the rest of the interface not just a cable.
spider
- x 77
Re: 307 ABS issue
I think the Planet / Lexia requires the full interface rather than a generic dongle.
The usual fault code readers etc usually only pick up engine codes not anything else like ABS or SRS issues in most cases.
Regarding the software *ahem* Google is your friend here.
Andy.
Gibbo_Wirral
Re: 307 ABS issue
Is it not just the rear sensor gap issue? Common fault on the 307, especially around the ten year mark.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
