C5 Fan motor
andybsmith
C5 Fan motor
Unread post by andybsmith »
Hi my fan motor has stopped working, checked fue under bonnet 40 amp seems ok, checked fuse no 24 or 25 under dash 15 amp seems ok, any ideas or is it a matter of stripping out the motor and checking that. Initialy when turning the ignition on the dash panel shows that the motor is set to full, but then nothing happens and the blades symbol goes to zero. The demister function doesn't work either. I hope some one can help me with this, the car by the way is a 2003 C5 2.2 HDI Exclusive.
Its a French car, it has foibles, patience is a virtue
Xantia VSX 155 bhp
C5 2.2 Exclusive
daviemck2006
x 485
Re: C5 Fan motor
Unread post by daviemck2006 »
Probably the ecu for the climate control. It's in the heater box and can be found in the drivers footwell beside the clutch pedal. Simple to change and easily available off eBay. That's exactly what happened to my first 2003 c5.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 5675
Re: C5 Fan motor
Be careful buying on eBay. Some sellers are charging around £120. I bought one last year for about £20 with a lifetime warranty.
I don't seem to have a record of the transaction but here is a similar one.
andybsmith
Re: C5 Fan motor
Update, it's a coolish evening and I set the climate control to 16 and started the car, the fan motor briefly started to work and then cut out (1 or 2 secs max) looking at previous replies to my post does the fan motor resistor act as an ecu for the climate control? I've looked by the LHS of the drivers footwell and found what appears to be roughly the same item in myglaren's link ie component with 4 thick wires and 2 very thin wires secured by two screws/bolts to the footwell. My confusion is that it isn't in the heater box like daviemck2006 said, also if this is the offending part does this indicate a deeper problem, or can these resistors just blow through old age. I must admit I am quite relieved that the motor does indeed start to spin because that indicates that it isn't jammed. I'll explore further in the morning when I an get the car on the drive and not have to dodge passing traffic.
Xantia VSX 155 bhp
C5 2.2 Exclusive
daviemck2006
x 485
Re: C5 Fan motor
I may be wrong about the heater box. It was a long time ago! The part that myglaren linked is what you want. Thinking about it it will be in a heater duct (maybe lol). It is a common fault and changing the unit should sort it out. Sorry if I confused you by saying the heater box!
Peugeot boxer 2016
In the family
x 5675
Re: C5 Fan motor
It is definitely in the heater duct. The heatsink fins get very hot (burned myself on mine when it fell out while driving) and needs the cooling airflow.
andybsmith
Re: C5 Fan motor
Thanks for the advice 1 new part on order as per myglaren's link .
Xantia VSX 155 bhp
C5 2.2 Exclusive
andybsmith
Re: C5 Fan motor
Well new part in and working, thanks for the advice, what a hellish job to fit the damn thing.
Xantia VSX 155 bhp
C5 2.2 Exclusive
daviemck2006
x 485
Re: C5 Fan motor
andybsmith wrote:Well new part in and working, thanks for the advice, what a hellish job to fit the damn thing.
You have to be a bit of a contortionist to do it [emoji1]
Glad it's working now.
Peugeot boxer 2016
In the family
