anti pollution fault
darbuck
x 290
Unread post by darbuck »
Hi lads ,
My c5 2.0 HDI has recurrent anti pollution fault but only when driven immediately after starting but if i leave running for a few minutes no faults. any ideas greatly appreciated the fault on lexia is air flow meter i replaced it with one out of a breakers but no joy. :?:
Darren
SwissSPEC
Re: anti pollution fault
Unread post by SwissSPEC »
Have you tried afm cleaner? its about a tenner for a bottle, worth a go on both your afm's if you kept the old one? the replacement may also not be working?
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
x 1983
Unread post by Stickyfinger »
Fuel filter getting blocked ?> ....when was it last changed ?
darbuck
x 290
Theres 3000 miles on the fuel filter and i have clened the afm with contact cleaner is there a way to check afm
Darren
x 1983
It can be a LOT of things giving that fault (which is generic almost)....it really needs a Lexia session to read what is the problem.
All else will be guess work really
Denzil
Unread post by Denzil »
Hi Guys.....I have the same fault intermittently on my C8 HDI SX.........One of the fault codes says airflow meter fault.....Where can I find it....It doesn't show in the exploded diagrams in the Citroen Doc backup software...and a search of said software by name doesn't come up with anything either....Thanks to anyone who can help......I'm not a dunce,but I think the software is written in such a way that it's meant not to be clear to the owners of the vehicles to which it relates....Thanks Guys..(and girls if applicable)
x 1983
See above.
Airflow meter [MAF] is inline with the air-filter/induction tubes.
darbuck
x 290
hi lads all the faults coming up are p0101 p0102 p0103 any one of theses faults come up when i connect to lexia but never all together their all afm related but as i said i swapped out afm at a cost of 40 blips and didnt work dont want to buy another if its something else triggering a fault or some sort of phantom fault by the way i ts original type by the way sticky how did you get on with your sticky situation.
Darren
wizaird
Locked user account
Unread post by wizaird »
Hi Darbuck , £40 for a MAF seems quite cheap ? Is it a genuine one ? I was told not to take any chances with a non genuine MAF when I had my 2000 C5 model 2.0 HDI ; That kept coming up with ANTI - POllution fault.
It had sporadic moments of non repaonsive accelration ...really slow. Then it would just go back to normal for ages.
I thought it was fuel filter and changed it and it seemd to work ....then it was back again.
It seemd whatever I did to it fixed it temporarily ? I suspected that it was clearing itself of the fault and getting by then realised the fault is still there and play up.
In the end I stumped up the £80 for a genuine one from Eurocar parts and hey presto ...it fixed it permanently.
Did another 20000 miles before I scrapped it with 200000 miles. Rear bushes went !
I now have a newer model which is a pain in the backside ...I am going through an EGR valve nightmare at the moment; check my other thread.
Anyway I still have that MAF SENSOR off the 20000 vehicle in my kitchen in a bag.......let me know if you want to try it out.
thanks Dave - Leicester.
Denzil
Hi Sticky...Many thanks for the info......It seems my C8 has the same poor acceleration fault yours had....But has only contracted this disease recently...Have got new Exhaust pressure pipes and sensor,but it would seem from your post that the airflow sensor is the most likely cause.......So Thanks you very much for your help....Cheers guys
Denzil
Correction to last post....Same problem as yours Dave......Cheers guys
darbuck
x 290
Hi wizard,
sounds like you had same problems as myself.im willing to try anything at this stage. I'm in Ireland so no way to collect unless i could paypal you the cost somehow.
cheers Darren
Darren
