Hi guys
I am getting ready to dump the green shell which will free up space for me to bring the Activa S1 donor into position.
Over time I will still like to keep moving it about every now and again, to do this I will need/like to keep it high on the suspension.
So the question is....How/What can I use to keep it up off the deck ?
Blocking up a Xantia's suspension
- x 1995
superloopy
- x 19
Re: Blocking up a Xantia's suspension
Whats the s1 donor for?
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
- x 1995
PartsNortherner wrote:Whats the s1 donor for?
superloopy
- x 19
Thought you were building another one [emoji4]
Mike
- x 1995
I could do, the car just needs a little welding to the floor
- x 94
the rear end you just remove the spheres with the wheels off the ground, place something like a long bolt/length of broom stick into the cylinder and screw the sphere back on,
the fronts you need to with the car on high wedge something ( a length of timber ) between the lower arm and the underside edge of the strut top
Regards, malcolm.
- x 1995
Cool....thanks Malcolm....one old broom stick used then, glad I kept it
- x 94
Stickyfinger wrote:Cool....thanks Malcolm....one old broom stick used then, glad I kept it
just dont tell her in doors why she finds she has to sweep the floor on her knees
Regards, malcolm.
