xantia estate door
sheldon6
xantia estate door
Unread post by sheldon6 »
my 98 1.9td drivers door has dropped so much so that it is catching the rear door as it closes. there appears to be play on the bottom hinge although the weld is solid to the door post outer, it still moves, any advise gratefully received.
AndersDK
Unread post by AndersDK »
You are not alone [:)] - try this :
http://www.andyspares.com/discussionfor ... IC_ID=5131
sheldon6
i have read the article with great interest. Do you know of any step by step instructions on how to repair the weld. I am guessing that the hinge would need to be drilled and then puddle welded to the inner structure. does anyone no if this is correct?
AndersDK
I donno of any welding instructions - sorry.
But try contact one of the owners in the thread - clicking their member name and submit an email.
