Lexia2 question
superloopy
- x 19
Lexia2 question
Does anyone else have an original Lexia workstation? If so, do you know the latest cdrom release it will accept? I've got v34.16 running on mine and was wondering if there are any later versions i could upgrade to? Bit of a long shot but someone might just know [emoji4]
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
- x 1055
Re: Lexia2 question
Not 100% but from memory I think the last update for lexia 2 was CD 36. Unless you have the full CAN adaptor lead though it's probably pointless updating, the updates were generally for new models to be added & pretty much every model from the mk2 C5 & the C4 onwards were full CAN. Most dealers had upgraded to Lexia 3 by that point & a full CAN adaptor for the old one was hundreds of pounds so not a lot of them had it. I also remember lexia 2 with the last update being painfully slow.
What's the latest model car on the list on your Lexia ?
prensel
Re: Lexia2 question
Hello,
I have just purchased a Lexia2 station to do some diagnoses and maintenance on my Saxo Electrique cars( i have three).
On the Lexia2 tablet version 37 is installed and the tool came with some CD's numbering from 1 to 6 and from 27 to 32. It also came with a bunch of cables like this:
- 37 pin Dsub to 16 pin obd2
- 37 pin sub d to round 30pin plug
- 30 pin round plug to 16 pin obd2
- 30 pin round plug to 2 pin plug
- 30 pin round plug to 1 pim plug
- Citroen ICC USB adapter to 16 pin obd2
I couldnt get the ICC adapter to work with the Lexia2 and my Saxo.
But the 37/obd2 cable did work perfectly on my Saxo.
The ICC does work however wit my generic XP laptop with Lexia 3v46 on the same Saxo.
At this time im looking for a cd or copy of the cd v37 to have it as a backup.
Maybe copies of the other missing cd's would be nice to have.
Also looking for a 30 round to 30 obd adapter to diagnose my 1997 saxo (which has a 30 pin square obd instead of 16pin obd2).
Il be appy to supply copies of my cd's if anyone wants them.
Thanks.
Paul
Thanks.
Paul
