Xantia handbrake adjustment
lazza
Unread post by lazza »
HI All
Long time since last post. Been busy and I only like to work under the car in the sun :). So it's that time of year again.
Something I want to try to sort out before my upcoming MOT is the handbrake, which is quite loose. You have to pull it up high before it really works.
Can anyone instruct me on an easy way to tighten the handbrake up??
Cheers
Larry
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
x 1990
Re: Xantia handbrake adjustment
Unread post by Stickyfinger »
The adjusters are on the calipers/cable mount, adjust from there to 2 clicks (3 max if done by a housewife with pmms when parking at the supermarket)
chinkostu
x 30
Unread post by chinkostu »
Dead easy if the bolts haven't siezed up :) if they have you might need to get some heat or molegrips to work them loose
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1990
chinkostu wrote:Dead easy if the bolts haven't siezed up :) if they have you might need to get some heat or molegrips to work them loose
Agree, they are sods to undo
As always, 25 hrs soaking with PlusGas is a very good thing....I used a soldering gas-micro-torch as I could keep the heat off the guide tube, I then cooled it with WD40 (got to use it up somehow) then waited 1 hour, came open OK then.
lazza
Thanks for the replies- any photos of what i should be looking for?
x 1990
The Haynes Xantia book will give you good coverage, really it is just an adjuster on the end of the handbrake cable/leaver that turns back to extend?shorten the cable/leaver height .
x 94
Unread post by citronut »
Stickyfinger wrote:The adjusters are on the calipers/cable mount, adjust from there to 2 clicks (3 max if done by a housewife with pmms when parking at the supermarket)
shame on you Mr Sticky
you never ever adjust the cables first,
the correct way to adjust these is, whit the car on level ground, engine running, hand brake off, press the brake pedal very hard two or three times,
they are meant to self adjust up in normal running but never do,
there is a but though,
if they still do not adjust up after doing the above,
firstly check the hand brake levers on the calipers are coming fully of with the hand brake released,
secondly check the pads are not worn away to next to nothing, as i find if the pistons are out a long way the mechanism has trouble adjusting up,
only adjust the cables after the self adjusting mechanism in the calipers is adjusted up,
Regards, malcolm.
x 1990
As it says in the Book of Lies...I assume to much you are correct.
chinkostu
x 30
I find my adjustment goes all over the place if i have the handbrake off and pump the pedal!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 94
Stickyfinger wrote:As it says in the Book of Lies...I assume to much you are correct.
#-o :wink:
oooh er,
can you elaborate
sounds like some ting aint set up right to me,
dont pump the pedal but just press it two to three times very hard
Regards, malcolm.
chinkostu
x 30
When it went in for its MOT, the handbrake was pretty damn tight. The other day it felt loose so i did the pedal pumping and it felt worse!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 94
something aint working/adjusted as it should be then,
sized caliper slides, caliper levers not returning fully off with hand brake released, cables binding, cables adjusted up wrong,
to name a few
Regards, malcolm.
x 1990
With mine (done after seals/disk/pad change), I took off the cable ends off the caliper arms, pressed twice, backed off the cable adjusters all the way and cleaned the threads, then adjusted the cables to the correct amount (just loose) on the arms.
x 94
Stickyfinger wrote:With mine (done after seals/disk/pad change), I took off the cable ends off the caliper arms, pressed twice, backed off the cable adjusters all the way and cleaned the threads, then adjusted the cables to the correct amount (just loose) on the arms.
this is the correct procedure after fitting new pads, although i unhook the cables from calipers fisrt, and leave them off till i have pressed the pedal two to three times ( engine running ) after fitting the new pads
Regards, malcolm.
x 1990
ah good, I will stop then :)
