xantia climate ecu
xf1ref
x 11
xantia climate ecu
Unread post by xf1ref »
Hello to all,
It is possible that ecu for climate control to fail?
Yesterday when I turned the engine on, the fan speed is at maximum for 5 second and after that, the speed slow to minimum.
The slider doesn't work anymore.
I checked the transistors from speed control unit and they are ok, also the climate ecu board is visual ok...nothing burned.
