The 3 litres of LHM I put in on Friday has gone, it probably went fairly quickly too, considering the froth I saw while the engine was running. The old saying that "a picture is worth a thousand words" is probably true in this case, so here it is:
The bubbles of frothy LHM are highly reflective, so the picture isn't great - but it does show where the fluid is coming from.
Is my HP pump knackered, or can this be repaired? Or is it possible that it just looks bad - it's frothing/bubbling around the circumference of what appears to be a join at the point indicated, not from the union itself.
Stu.
