Hello, new 206 SW owner
Ross74H
New User
Unread post by Ross74H »
Hello,
Just joined the forum and thought I would introduce myself. I have brought a 206 SW Dturbo as my daily driver a while back and I have just started on sorting out a few of the problems it has got and then it should be up and running as my daily driver.
Anyway, thought I would join for help and advice with regards to getting it up and running.
First problem is getting the wonky rear wheels sorted - I have been told that its due to failed "rear trailing arm bearings" so I am guessing I need to swap the rear axle out, I have been looking at rear axles from GTI 180s on ebay but not sure if these will fit.
Anyway, be good to be part of a friendly forum
Ross
x 8444
Re: Hello, new 206 SW owner
Welcome Ross :-D
Yes, definitely a rear axle swap job... It was a very common failing on the 205 too... Once they're wonky it's a specialist job to fix them.
You need to be careful over what you swap to depending on disc or drum rears as the stub axles are different....
