sorry VW question fault/code opinion required
x 94
Unread post by citronut »
i know its not french,
i had a customer come to see me asking if i knew what is involved in sorting fault/code P2203,
on doing a goooogly search it comes up with "NOx Sensor Circuit High Input (Bank 1)",
there are people on the internet saying the Nox sensor is dealer only at a cost of between £300 and 400 squid,
anyone had experience and know the best way forward
thanks in advance
Regards, malcolm.
x 94
Re: sorry VW question fault/code opinion required
someone must know about these jeer mun things
Regards, malcolm.
x 2007
Unread post by Stickyfinger »
http://www.volkswagenforum.co.uk/f33/go ... -4698.html" onclick="window.open(this.href);return false;
seems common
lerch sprung technica
ACTIVE8
x 6
Unread post by ACTIVE8 »
Stickyfinger wrote:http://www.volkswagenforum.co.uk/f33/go ... -4698.html
seems common
It also seems very expensive, reading through the posts on the Vee Dub forum.
ACTIVA
spider
x 77
Unread post by spider »
Pity you're not a bit nearer Malcolm as I have a vcds/vagcom which would determine if it really is that at fault or not ie live data amongst other things.
Andy.
