Seeing as I'm going to be getting my hands dirty this weekend I might as well see if I can make my speedo and tacho work properly again too. So, I have a couple of questions about these.
The Speedometer - does anyone know if the drive is electrical or mechanical on these cars ('95/M TD LX )? I suspect it's electrical due to the behaviour of the needle under fault conditions, but would like confirmation. If that IS the case, where is the sensor? I've had a cursory look, but can see very little in the gearbox area!
The Tachometer - I know that this is definitely an electrical feed. Again, I need to know where to find the sensor!
Thanks,
Stu.
Xantia TD Instrument sensors?
