Adding USB port
Phatbox
Adding USB port
Unread post by Phatbox »
Hi All
My 2010 C3 Picasso only has the 3.5 Aux port, is it possible to replace with the combined Aux/USB port, is the wiring in place and connected to the radio/CD to do this?
Many Thanks
vborovic
Locked user account
x 40
Re: Adding USB port
Unread post by vborovic »
Depending on your radio/nav unit, but I doubt it ... if the radio/nav unit has the USB capability, it would definitely have it factory fitted ... depending on the actual unit, it might be possible to add the usb cable, but the options are very limited ... the USB BOX solution could be installed in the place of a CD changer (either PSA onre, or afermarket, like Dension etc)
