i have now tracked down an oil leak in the dw8 from the cam cove/box which is fixed to the sump pan, which has a pinhole and is losing a fair amount of oil.
my problem is sourcing the sump pan and gaskets, could someone advise from which other models would the sump pan fit my 306 dw8 without a/c and what difference is there between the lot - xud, partner, berlingo, dw10, Citroen etc. i would like to get a second hand sump maybe alloy which i think needs longer bolts, mine is steel. i have hylomar 100 series silicone and might put paper gasket on as well, ill see whats on when i get it off.
would this fit for example - http://www.amazon.co.uk/Febi-19187-Sump ... elId=11422" onclick="window.open(this.href);return false; only £3.75 from amazon.
i have seen new sump pans on ebay etc for around £40 but might look local
thanks
engine oil sump pan replacement
Re: engine oil sump pan replacement
if you send me the last 8 digits of your chassis/VIN No. i will check on pug service box and cross the part No. onto service citroen,
i have not had the pleasure of dismantling a DW lump as yet, but are you sure the bolts from the cam cover go trough and into the sump?????
Regards, malcolm.
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
From memory generally the steel pressed sumps are fitted to models without AC and the alloy sumps* fitted to those with AC, although the results can vary a bit.
*Some of the alloy ones have surprisingly fragile sump threads too, not many thankfully.
7 - CYLINDER HEAD ASSEMBLY
(e) Identification area .
(4) Upper cylinder head cover (Of a composite material) .
(5) Lower cylinder head cover .
(6) Cylinder head .
(7) Glow plugs .
(8) Injector holder .
(9) Fire ring .
(10) Camshaft .
7 - 1 - UPPER CYLINDER HEAD COVER (WITH INCORPORATED OIL SEPARATOR)
The seal is preformed and removable .
The oil filler hole is incorporated in the cylinder head cover .
7 - 2 - CYLINDER-HEAD COVER
Material : Light alloy .
7 - 3 - CYLINDER HEAD
Component making it possible to obtain the best compromise between performance, noise and emission control standard :
cylinder head with ADVANCED COMET RICARDO technology pre-combustion chambers
diesel injector placed in front of the glow plug
(e) Identification area : 2 holes, diameter 9, below the injector housing (cylinder no. 1 and no. 3) .
NOTE : tightening is in a SPIRAL sequence .
7 - 4 - INJECTOR
The fire ring (9) is inside the injector holder .
NOTE : the injector carrier and cylinder head sealing washer must always be changed following every operation .
7 - 5 - CAMSHAFT
DW8 engine (Identical to XUD9A engine) :
the camshaft is secured by 3 light alloy brackets
the camshaft drives a vacuum pump (flywheel end)
The side clearance must be between 0,025 and 0,7 mm .
Identification of the camshaft by means of a blue paint ring between the intake and exhaust cams of cylinder no. 1 .
Andy.
