Baffled by the Technology.....
Xantianut
x 127
Unread post by Xantianut »
Ay up!!!!
Nowt new here eh?
Well, a lumpy parcel arrived today containing the replacement door locks, steering lock, transponder ring, ECU, fuse box and, interestingly, the passenger airbag switch.
Now, I know the fuse box is not computerised so no worries there. I was wondering what would happen if I switched the ECUs over? It is the same part No as the existing unit but I have read horror stories about the BSI not talking to a replacement and also refusing to recognize the original when refitted. Any advice? Or is the answer leave well alone? It would be nice to have one key for everything, but, if this causes problems, wil retain the 2 key system.
The other question Imhave is regarding programming the fobs. Their batteries are in rude health, returning just over 3v on my multimeter. I've read several different accounts of which buttons to push and for how long and this has given me a migraine!!! So, in terms that a Technophobe can understand, how should I do this? Or is the answer impossible to program a 2nd hand fob to the ECU?
Please help...... [-o<
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
Northern_Mike
Re: Baffled by the Technology.....
It is impossible to program a 2nd hand fob on a C5 MK1
Sent from my SM-N9005 using Tapatalk
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Its impossible without a lexia!!
You can only swap an ecu as long as you have the matching bsi to go with it and also matching keys as a whole matching kit if you don't have a lexia. Without a lexia with a c5 your rather stuffed its needed for everything
There is a section in lexia you can get it to match up keys. You need them all to hand though as it will do then one at a time.
A very sad...
1994 XM 2.1 d auto
Northern_Mike
citroenxm wrote:Its impossible without a lexia!!
You cannot match a secondhand key fob to another C5 with or without a Lexia, unlike Xantia.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
That's been my experience too. Once they stopped using the separate chip units and went to an integrated board, the immobiliser transponder became a "one shot" item.
Xantianut
x 127
Thanks, chaps.
I'll just use the locks then until I get myself a Lexia.
RIP
BX19DTR (Fifi 2)
Xantianut
x 127
RHS lock fitted and amazingly I didn't need an extra joint in my forearm!
Now for the LHS......
RIP
BX19DTR (Fifi 2)
Xantianut
x 127
Ay up!
OK - locks now fitted.
So, with Lexia, it is possible to program the plipper to the car, is it?
And, as for the transponder, where does the chip lurk and how do I get to it? I can't work out either!
RIP
BX19DTR (Fifi 2)
citroenxm
Fallen Hero
x 70
The chip is in the large plastic part of the blade. Remove the key blade from the plipper and one of the sides will come off and the chip is in there.
A very sad...
1994 XM 2.1 d auto
Xantianut
x 127
Thanks for that.
Transponder chip located and now thinking up my next move here. How easy is it to program the car to a virgin transponder chip? I am wondering about doing a transponder by pass with all that entails but the insurance issues suggest it's a bad idea.
The chips are out there and cheap enough, about £4 each. Plenty of time before I get a Lexia.
Any ideas, folks? I'm all at sea with computers.
RIP
BX19DTR (Fifi 2)
