My starter motor is showing signs of being on its way out and I can harvest one from a spares repairs Peugeot 405. They're both the XUD engine so I'd assume they're one and the same
Can anyone confirm one way or the other?
Are 1.9D Synergie and Peugeot 405 Starter Motors the same?
kenbw2
- (Donor 2017)
- x 24
Stewart(oily)
- x 35
Re: Are 1.9D Synergie and Peugeot 405 Starter Motors the sam
All of the diesel ones seem interchangeable, though some of the older ones are longer in the body.
kenbw2
- (Donor 2017)
- x 24
Is that extra length something that can cause a problem, or is the space sufficient for both?
- x 94
here is a the list of pugs that comes up on an all families search on Pug service box
all these are diesel's
with this part No.
5802 M3
4 document(s) found for 406
3 document(s) found for 307 RESTYLING
2 document(s) found for BOXER 2
1 document(s) found for 605
1 document(s) found for 205
4 document(s) found for 807
2 document(s) found for PARTNER VP (M59)
1 document(s) found for 405 SAUF RESTYL
1 document(s) found for 309
2 document(s) found for 206
2 document(s) found for 307
3 document(s) found for 306
1 document(s) found for 205 A PARTIR MOD 1991
2 document(s) found for PARTNER VU (M59)
3 document(s) found for 406 (RESTYLING)
1 document(s) found for 607
2 document(s) found for 407
1 document(s) found for 4007
8 document(s) found for 306 (RESTYLING)
1 document(s) found for 607 RESTYLING
2 document(s) found for EXPERT
1 document(s) found for J5-Express
2 document(s) found for 806
and the same on service citroen
5802 M3
3 document(s) found for BX
5 document(s) found for C25
1 document(s) found for XSARA II
3 document(s) found for C5 II
1 document(s) found for C4 PICASSO
1 document(s) found for XM
2 document(s) found for C15
2 document(s) found for BERLINGO VU (M59)
2 document(s) found for XANTIA II
2 document(s) found for RELAY
3 document(s) found for C4
1 document(s) found for C-CROSSER
1 document(s) found for XANTIA
2 document(s) found for SYNERGIE
4 document(s) found for C8
1 document(s) found for C5
2 document(s) found for BERLINGO VP (M59)
2 document(s) found for DISPATCH I & II
1 document(s) found for XM II
1 document(s) found for XSARA PICASSO
1 document(s) found for ZX
3 document(s) found for C5 (X7)
2 document(s) found for XSARA
2 document(s) found for RELAY II
with this part No.
5802 M3
5802 M3
Regards, malcolm.
BX
- x 19
As far as I can see from fitting starters, practically all the 1.9 and 2litre HDI starters are interchangeable. I know that a starter from a 405 1.9 diesel will fit the 2.0l 16 valve HDI. 1.4 & 1.6 HDI engines have the starter fitted to the back of the engine. They probably can interchange I.e between 1.4 & 1.6.
- x 1240
I think the main difference is that the early ones didn't have the reduction gearing but they will all work.
