Thread Size
2cvman
Thread Size
Unread post by 2cvman »
Hi Guys,
Have a C5 front strut. The feed line has a large 14mm???? thread size.
Questions.
1. Does this use a Banjo bolt to connect?
2. What size is the thread M14 x 1.25??
Plan to use on a 2CV :-D
Any info gratefully received.
Cheers
x 94
Re: Thread Size
Unread post by citronut »
hi and welcome
do you know what variety and year C5 the strut came from,
they dont usually have a banjo coupling, but just a flare nut that screws straight into the strut top,
what are you going to use it for opening the dersh bonnet :yikes: :-D :lol: :rofl2: :rofl2: :wink: ,
you are also aware the C5 does not run on citro green blood
were are you located
Regards, malcolm.
2cvman
Re: Thread Size
Hi Malcolm,
Thanks for the reply, purchased two, first has a M10 connector, the other a 14mm? thread, both from as 1.8petrol 01 - 04 car.
I can make an adapter if I know thread size.
Not for the bonnet :-D
Have built 4x4 2cv, want to have height adjustable suspension!
FYI http://www.international2cvfriends.com/ ... 56#p119756" onclick="window.open(this.href);return false;
Cheers
x 94
Re: Thread Size
ok
how/were are you planing to mount the struts?????
you didnt say were you are located
Regards, malcolm.
2cvman
Re: Thread Size
Updated my profile.
Plan is to modify the rear suspension to start with...
New bracket on the top of arm to push with the strut parallel to the chassis,
in the rear seat footwell.
Will link to some pics when I re-gain access to my Flickr account, It seems Google and Yahoo have fallen out??
Cheers
x 5688
Re: Thread Size
How are you accessing Flickr!?
I had to shift my account from BTYahoo! to Yahoo! as BT & Yahoo were divorcing.
I can access Flickr! fine on Google Chrome through my Yahoo account, all works fine today (not always the case with Flickr!)
2cvman
Re: Thread Size
Created a new Flickr account, I think Yahoo have lost their way :(
See https://www.flickr.com/photos/132763931@N04/?details=1" onclick="window.open(this.href);return false;
Last image gives and idea of the strut position.
Still now info on the Thread size, its NOT M14...
x 2008
Re: Thread Size
Unread post by Stickyfinger »
2cvman wrote:Created a new Flickr account, I think Yahoo have lost their way :(
There is room in there for a 1600 flat 4 AlphaSud engine :)........good job.
x 94
Re: Thread Size
nah better put a 1300 GSA lump with a 5 speed box
Regards, malcolm.
2cvman
Re: Thread Size
One upgrade/modification at a time 8-)
2cvman
Re: Thread Size
M16, now need to determine the pitch.
Looks like 1.5mm?
2cvman
Re: Thread Size
Part made adapter...
See " onclick="window.open(this.href);return false;
Does anybody have a C5 Suspension/Steering pump For Sale or swap??
Cheers
2cvman
Re: Thread Size
Hi Guys,
Have a C5 pump from ebay:)
Can anybody tell me the colour(s) of the cable that runs from the 40amp fuse to the pump?
The pump has two large cable one is 12 volt the other is earth, but which is which at the pump end, have used a multimeter but still not sure.
Cheers
elma
x 284
Re: Thread Size
Unread post by elma »
I don't know the answers but one of these would find the pitch in no time.
Cool project, I'll be keeping an eye on this one. Always fancied doing the same to an old van myself.
2cvman
Re: Thread Size
OK on the gauge, its on the wish list:)
Now have the thread details as I obtained a union.
At the stage of wiring up the pump/electro valves, hence the question on the pump wiring.
Will post links to pics/video when its going?
Cheers
