xsara mk1 Estate outer sills.2.0hdi.
simonelsey
Unread post by simonelsey »
Hi all still got the car , no issues for a time ... Issue is Where the hell can I get outer sills (driver side) (but would assume passenger side need doing soon ) ,
MOT advisory Outer sill starting to corrode .... I've looked at it today ,(been few weeks since mot) and I would say They are Knacked ..Need replacing. Not starting to corrode..
Where Can I get these apart from Stealer . Cars coming up to 200,000 is it worth doing cars ok apart from this.... (lots on net about rot from inside sill) but hard to locate part.
2.0 hdi xsara estate been a pain but starting to look like a good buy
x 1996
Re: xsara mk1 Estate outer sills.2.0hdi.
Unread post by Stickyfinger »
Depends, normally there is a lot of tin worm all over the inner jointed areas and inner panels, the subframe mounts as well.....normally I would say Shoot It.....but that depends on the extent of the rot/who does the work/cost....that said there will not be much change from a min of £300 with paint and you will likely see problems back after next winter as well.
Good cars of the type are £500-800
x 94
Unread post by citronut »
is this what your looking for
http://carz2.co.uk/citron-xsara-break-n ... 5168-c.asp" onclick="window.open(this.href);return false;
i have used this company and found them to be very good,
i purchased a sill for my friends Piscasoooooo and even though it was not on there web site, on phoning them they toll me they had some on order, they even called me back when they said they would
Regards, malcolm.
simonelsey
Thank you
