If course, I've had it nearly two months now so it was inevitable some errors would appear..
"Vehicle speed control system faulty".. cruise inoperative.
Switching it to "off" then back on again makes it work.
Any ideas?
I also get parking sensor errors when it rains.
Sent from my SM-N9005 using Tapatalk
C4 Cruise error
- x 1488
Re: C4 Cruise error
Lexia.... could be stalk, COM unit, BSI, underbonnet fuse box, brake pedal switch, wiring, speed sensor etc etc! Take your pick!
daviemck2006
- x 485
Re: C4 Cruise error
I got parking sensor errors when raining on the c4vts also Mike. On the c5 I didn't get errors but it would beep occasionally when nothing there. Never had cruise control errors.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
Fake Concern
- x 65
Re: C4 Cruise error
The cruise problem (also speed limiter) spray some contact cleaner on the switch & twist it back and forth a few times, also move the steering column adjustment back & forth & in & out to clean contacts.
I have recently changed the brake light switch with the upgrade & still sometimes get the error, but twisting the switch a few times clears it.
Northern_Mike
Re: C4 Cruise error
Thanks all, I shall have a play tomorrow afternoon - I didn't get a chance to either get it on Lexia, or fiddle with it at all today. I was doing my good deed for the week, which took rather longer than expected! I did end up parked outside a Maplin for a while, and meant to go in and get some Servisol but had a sleeping child in the car, and then forgot to get it when my missus reappeared some time after. That's tomorrow's task sorted then..
