Xantia Front Caliper repair kit
MikeT
x 232
Unread post by MikeT »
It's been a long time since I fitted new pads and this year's MOT advised they (and front flexis) were worn so I'm gearing up to replace those. New pads, springs, pins and hoses ordered.
However, I have a vague memory of one of the piston seals/covers being malformed as winding that piston back in showed it was not retracting neatly with the piston (though the brakes have functioned perfectly since) and will most likely be worse this time round. As money is the biggest factor for me, do I go for complete overhaul kits and do both calipers or can I get away with just repacing the one single boot (bearing in mind I don't plan to keep the Xantia much longer)? Haynes doesn't give me a caliper overhaul guide (says refer to kit instructions) so not sure how much dismantling is required to replace just this one seal.
x 3296
Re: Xantia Front Caliper repair kit
This lot are good for caliper kits, if you need one;
http://www.biggred.co.uk/" onclick="window.open(this.href);return false;
MikeT
x 232
Hell Razor5543 wrote:This lot are good for caliper kits, if you need one;
That'll probably be the next question - to get kit with or without pistons and best price(s).
MikeT
x 232
Got parts (pads, pins, springs and hoses) now but I'm still concerned about this piston seal/boot that awaits me and if it'll need replacing once I've got the car dismantled. I can't find single seals to buy but even if I bought a full caliper service kit, is it possible to replace this single item without having to fully dismantle the caliper? Would be good if I could just wind out the piston, clean, fit new seal and wind back in without delaying the work by having to fully refurbish a pair of calipers.
Photo for illustration purpose (might not be same as mine but piston/seal looks similar).
x 94
Unread post by citronut »
i have not taken one of these calipers apart before, but i think the dust seal/boot on at the piston side of the caliper, is fitted into a groove in the caliper body whilst the piston is removed
Regards, malcolm.
MikeT
x 232
citronut wrote:i have not taken one of these calipers apart before, but i think the dust seal/boot on at the piston side of the caliper, is fitted into a groove in the caliper body whilst the piston is removed
Probably. Just hoping that if it does require attention there may be a way to do it in-situ to save work/time but it's unlikely and if the caliper has to come off and be part-dismantled to remove the piston, might as well overhaul completely and, of course, one can't do just one side so double the pain. #-o
