Xantiaq headlamp/relay Mod
x 1980
Unread post by Stickyfinger »
Would like to update the main feeds for the headlamps (got my projector lens', so need to make good high power relay feeds) and I can't find a diagram.............is there one on the forum ?
xf1ref
x 11
Re: Xantiaq headlamp/relay Mod
Unread post by xf1ref »
If you only want to by-pass the main switch for main and dipped beam you will need 2 relays ~20Amp each.
The modification is at fusebox in engine compartment and you will feed the bulbs from battery +
chinkostu
x 30
Unread post by chinkostu »
Get a 4 pin relay (not sure on exact name but the ones that run the fans are the same), run a nice thick guage from terminal 30 to the battery or fusebox live and run 85 to ground. Be sure to use a fused wire for the positive!
Now, what I do is trigger the relay from the original wiring using a scotchlock as it pulls minimal current just switching a relay, you'll have to figure out which is positive and earth though. Then terminal 87 run a nice fat wire to the lamp. You only need thick wires for these as the original wiring is only triggering the relay and the bulbs will be running off of the new wiring.
You'll be best then taking the earth from the lamp and running a thicker wire from there to a decent ground on the car. You will probably be able to run both lowbeams from one relay if your wire is thick enough (i ran 2 spotlights on a previous car this way) however you won't be able to run mains and low from one relay for obvious reasons ;)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
This link explains the benefit of carrying out a headlamp relay mod very well complete with wiring diagrams.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1980
DickieG wrote:This link explains the benefit of carrying out a headlamp relay mod very well complete with wiring diagrams.
Found this only a few mins away....all standard stuff then, good. Learnt to check even the "simple" things with Citroen....plus I am as self confident as a mouse in a cats home when it comes to my spannering....thanks for the assistance chaps.
chinkostu
x 30
You can also buy the relay prewired with decent lengths at halfords/motoring shops, not sure how much more they are.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1980
I have all the relays from the two scrap cars...I am sure they will be in there...and a Motor factors to assist avoiding Fraudfords :)
chinkostu
x 30
Good good :D when you break the wiring diagram down its actually really simple, if you can find the elusive twin 87 relay it makes wiring a smidge easier, otherwise you have to try and crimp two wires into one spade which can be snug!
A crimper or solder and soldering iron wouldn't go amiss either!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1980
All will be soldered for sure, I hate crimps and scotch blocks more than I hate Chelsea, Man-U and Justin Bieber added together.
Northern_Mike
You'll be adding Aston Villa to that lot on the 30th May..
Sent from my SM-N9005 using Tapatalk
x 1980
Well all I can say is LeBoss is doing his stuff again.. weeeee are on a roll again mate :) .....and how much have the others spent over the last 10 years ?
.....really tho, Villa are trying hard atm, fair play to them.
Northern_Mike
Stickyfinger wrote:Well all I can say is LeBoss is doing his stuff again.. weeeee are on a roll again mate :) .....and how much have the others spent over the last 10 years
And how much, apart from one FA cup, did you win over the last nine years?
x 1980
We won the Best Stadium in the UK, no billion pound loans and Europe every year, always top 4 and a sprinkle of silver......jealous ? ........ 8-[ [-X :)
edit....LOL....the use of We...as if I did anything to help...:)
Northern_Mike
West Ham have got the best stadium and you've just confirmed that you've not actually won anything :-) A team made up from FCFers could have won as many trophies or promotions as Arsenal did for 9 years :-)
I'm both a Burnley fan (family thing we had shares since 1948!) and a closet Man U fan from years of living abroad and having to have an English team to support that was actually winning In Europe. So no, not jealous :D I think Man U and Burnley won a couple of things
x 1980
All about being "always there" with us Gooners, which ever way you look at it we are that.
Disagree about WestHam's new one.....not at all like the Family home at the Emirates, it will not have the atmosphere I think....Chairman at West Ham is switched on however with that price drop, She will cause a few ripples at Arsenal with our prices :) ....Sunderland on the 20th is my next trip up
