C5 hdi Power Steering and Suspension pumps
ken.chapman
Unread post by ken.chapman »
Does anyone know where the Power Steering Pump and the Suspension pumps are on my C5 with last 8 on the VIN 54028743?
There is a pump under the reservoir - is this suspension or Power Steering?
Still having problems which no garage can sort - the suspension is hard and the steering heavy and notchy with no centre action as I drive. I was told a steering column (at £400!!) which was not the case and can only now assume the rack needs changing - can anyone recommend where to get a reconditioned one?
Thanks to everyone for the information regarding spheres - is there a way to test before replacing?
Lexia is completely free of faults.
Ken Chapman
C5 2008 onwards (Phase 2 X7) Excusive Auto Saloon
Last 8 on the VIN: 54028743
Aircraft Engineer and Global Quality Manager who doesn't like working on cars!
qprdude
x 14
Re: C5 hdi Power Steering and Suspension pumps
Unread post by qprdude »
Suspension pump should be under the fluid reservoir which sits on the offside inner wing (ish)
Rick.
2013 Citroen DS 5 D/Sport
ken.chapman
Thanks, any ideas about the Power Steering Pump?
Ken Chapman
qprdude
x 14
I could go and have a look, but it's dark now. :wink:
Rick.
vborovic
Locked user account
x 40
Unread post by vborovic »
It should be somewhere behind the front right wheel arch cover
x 1490
Suspension pump under the tank; PAS pump under the RH wing as said. Hope you don't need either of them....
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00005277K1 HYDRAULIC UNIT 771.41 GBP 925.69 GBP 925.69 GBP
00004007YP ELEC PUMP P A S 536.27 GBP 643.52 GBP 643.52 GBP
:twisted:
x 5672
Try lubricating the steering UJ.
Awkward to get at but white spray grease with a long 'straw' can be helpful.
x 94
Unread post by citronut »
does the car rise and fall on operating the manual height switch in the car???
if it does then the hard suspension could be down to flat suspension spheres, if it does not then i believe the suspension pump can be removed, striped, cleaned and re/assembled,
i have not done this personally, but have been told it works,
i think the main fault is dirty/sticking motor brush's/ brush gear
Regards, malcolm.
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Power steering pump is next to the hydraulic pump & reservoir, to it's right as you look at the engine from the front (2.0, 2.2)? It's easy to get at. I've just been to a local breakers and they've got several in that seem to fit the bill, about £20-£30 normally. Sounds strange that they're both playing up at the same time. Fluid's common to both though.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
x 1490
Monkeyfeet wrote:. Fluid's common to both though.
Not on an X7.....
