synergie 1.9td oil
Harlequin
x 23
synergie 1.9td oil
Unread post by Harlequin »
So been given some tesco own 10w40 mineral oil . Ok to use in my old td?
It's API SL
ACEA A2/B2
Simon
Northern_Mike
Re: synergie 1.9td oil
Yes.
Sent from my SM-N9005 using Tapatalk
x 94
Unread post by citronut »
are you sure its 10/40 mineral Simon????
10/40 is usually semi synthetic,
if it is mineral check if its specific for petrol of diesel engines
Regards, malcolm.
Harlequin
x 23
its why I asked - it says its:
http://www.tesco.com/groceries/product/ ... =258763398" onclick="window.open(this.href);return false;
on the bottle (4litre ones)
Simon
Zelandeth
x 1604
Unread post by Zelandeth »
I would be uneasy using that in a diesel. They produce a lot more carbon internally than a petrol engine, hence the oil usually has more detergents in to help keep the engine clean. That's why the oil almost immediately goes black after an oil change, whereas in a petrol engine it can still be a healthy golden brown after six months when it's due a change.
Have always been taught that any turbocharged engine should always be fed a diet of good quality synthetic oil too, so that's what my 1.9TD runs. Main reason for this being the high temperatures encountered in the turbocharger bearings which can cause mineral oils to break down.
I'd have that off you if you were closer though as it would do fine for my Skoda which will be happy with anything that looks vaguely like oil...
I've used diesel oils in a petrol before to help clean out a previously poorly maintained engine, but would never do the same in reverse.
These are just my views. If folks with far more experience come along and say it's okay I am happy to bow to them. The XUD is a tough old engine after all, and may well be far less picky than the more modern units. I prefer to play it safe though.
Current fleet:
Northern_Mike
Zelandeth wrote:I would be uneasy using that in a diesel.
It's the original spec oil for the XUD.
Harlequin
x 23
the spec on the bottle says ACEA A2/B2
the B2 indicates its diesel as well?
but the API is rated at SL (but not CF as well)
S being petrol and C being diesel?
reading
http://www.google.co.uk/url?sa=t&rct=j& ... XxyA-6QLaw" onclick="window.open(this.href);return false;
I really should be getting ACEA A3/B3
thanks chaps - thought it was too good to be true!
Simon
x 94
Simon you could always use it in your lawnmower, or maybe in your deep fat fryer :shock: #-o :-D :lol: :wink:
Regards, malcolm.
Harlequin
x 23
lol - ECP (yes I know) have some 15x40 shell helix (ACEA A3/B3) diesel for £16 for 5 litres
Simon
x 94
10/40 semi synthetic is all you need, and i think Asda is usually quite reasonably priced
Regards, malcolm.
Richard_C
(Donor 2026)
x 231
Unread post by Richard_C »
I'v e used Tesco 10-40 mineral diesel oil in mine for years, probably ever since it camel out of warranty and I started servicing it myself. No excessive oil consumption (max 1/2 litre between services) no troubles. I change oil and filter every 6k miles. It comes in a black 4l container. (Years back it was 5l so I always had a bit left over, now its 4 you sometimes need a bit more for the mid term top up)
Richard_C
Harlequin
x 23
its blue not black bottles - they are going to exchange it for me anyway (at current price) - so its£10 towards something suitable
Simon
