Xantia HDI Gearbox
trsaab
Xantia HDI Gearbox
Unread post by trsaab »
I have recently purchased a 1999 HDI and found selecting 3rd and 5th in particular to be difficult. Local Citroen garage said oil was contaminated by water getting in through the breather. They drained and refilled and it cured the problem. With todays rain the problem is back. Anybody else had this problem and know of a fix - block the breather seems a bit drastic but ant suggestions please.
AndersDK
Unread post by AndersDK »
Seems a simple deflector plate of some kind needs be installed.
Or simply a breather with a longer pipe under the breather cap.
What about clutch cable adjustment - does the clutch pedal rests sufficiently high over the carpets ?
trsaab
That's what I thought, with a pipe going above splash level.
Clutch sits Ok, I don't think the cable is adjustable, I'll check when it stops raining.
blueboy2001
Unread post by blueboy2001 »
Be a hydraulic clutch on a HDi won't it?
AndersDK
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">.... with a pipe going above splash level<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Simply try first if the breather cap is easy to remove - then if a lenght of PVC garden hose will fit over the stud - cap fitted on hose end.
... then sue the garage if they ever remove it [;)]
x 1061
Unread post by wheeler »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by blueboy2001</i>
you can get Xantia HDi's with cable clutches.
Rich
Unread post by Rich »
Hello,
Yep, that's right, my HDi has a hydraulic clutch but my dad has a HDi with a cable clutch.......[?]
Rich. Xantia Exclusive HDi.
