Correcting turbo boost on hdi 110
harryp
(Donor 2022)
x 73
Unread post by harryp »
Thought I'd start a new thread. Does altering the length of the actuating rod actually alter the turbo pressure, or is the whole system electronically controlled by feedback. It seems it should be, but after purchasing the car it was apparently throwing an error of "low boost pressure". If so, by how much thread to start, 1/4 ,1/2 turn? and of course,which way; more closed/open; shorten/lenghten?? Of course the values 1/4 turn etc are only mentioned as I have no idea of the sensitivity, and not wishing to reinvent the wheel.... Has anyone tried?
Best regards,
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
Stewart(oily)
x 35
Re: Correcting turbo boost on hdi 110
Unread post by Stewart(oily) »
Shortening the rod used to increase boost on the older 1.9 TDs
On my HDI 110 I was getting an intermittent engine light (after hard acceleration) that has been totally cured by replacing the turbo electrovalve, full power restored and a lot more driveable, as an added benefit replacing the electrovalve is a clean hands job.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Sadly altering the Turbo boost on the Wastegate WILL throw up an error more frequently without having the ECU altered in the set settings to accept the higher boost!
The ECU controls the Turbo boost pressure to a SET value in the ECU via the Electrovalves, by increasing the physical turbo boost by allowing more in past the wastegate may very well upset the ECU.. best left alone on the HDi engines sadly.
At least this is how I beleve it to operate and work, and while I did 138k in mine and went to 283k I never adjusted my turbo and found the 110 still extreamilly acceptable .
I beleve remaps adjust preset setting for turbo boost allowance etc.
A very sad...
1994 XM 2.1 d auto
harryp
(Donor 2022)
x 73
Thank's chaps.... Mmmm, not much light at the end of that particular tunnel then :roll:
Regards....
Regards, Harry
