Hi Guys,
Can someone clear up engine configuration for me?
I have a 2006 Xara Picasso 1.6 16v petrol. NO problem? Well yes it is, several times I have attempted to buy parts from online suppliers where you input the registration for the vehicle and you get a list of compatible engines, except is always says the part won't fit my engine!
Last year I stupidly left the oil filler on the block after topping up, resulting in me going down to the main dealer to get a new one. It had to be ordered in specially because the 'standard' one doesn't fit my engine! When it arrived the parts man showed me the two together, mine is smaller in diameter and longer than 'standard'
So what model engine does it have and why a difference over the other petrol versions?
Engine confusion
- x 1987
Re: Engine confusion
If you post the last 8 digits we can help..and welcome to the FCF
Brian56
These are the last digits showing in the windscreen--25775880.
I de-registered it as a UK car last December and it is now Spanish registered. My current problem is sourcing an aircon compressor, with so many types/makes I'm having a heck of a job choosing the right one to fit.
- x 1480
service.citroen shows engine type as TU5JP4
Of the AC compressor it says:
6453 QE
RP 98 008 222 80
01
01 NEW COMPRESSOR
SANDEN INT- - SD6V12 1449
6453 QE was the original part number, now superseeded by 98 008 222 80.
and shows a compressor bolted onto the block with front/rear bolts rather than the more normal side to side.
6453 QE
RP 98 008 222 80
01
01 NEW COMPRESSOR
Brian56
Thank you richard. How do you find this stuff? I've spent eons doing google searches with no result!
- x 1987
http://service.citroen.com/socle/?start=trueBrian56 wrote:Thank you richard. How do you find this stuff? I've spent eons doing google searches with no result!
you need to register.....endlessly helpful.
