Hi Guys, nice to be back. I am restoring my ZX but engine won't start and I want to make sure that the spark plugs are connected in the right order (I suspect somebody might have tampered with them).
Does somebody have pictures or diagrams of how spark plug cables go into the coil? I have spark, there is fuel pressure but the engine won't fire, not even tries to run.
Thanks!
Engine Pictures
oscarloco
Engine Pictures
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
- x 1489
Re: Engine Pictures
Firing order is normally 1-3-4-2, and 1 is usually at the flywheel end. So get it up to compression on No1 cylinder, then pop the top off the distributor, and check which post the rotor arm is pointing at, and fit the plug lead for No1 to that post, then work round the lid in the firing order, and it should be right. Not unknown for people to remove the rotor arm to prevent theft, and then forgetting to refit it...
- x 1240
Re: Engine Pictures
What are spark plugs?
oscarloco
Re: Engine Pictures
Thanks. Any chance you got the pictures? You know, for a less hassle approach?RichardW wrote:Firing order is normally 1-3-4-2, and 1 is usually at the flywheel end. So get it up to compression on No1 cylinder, then pop the top off the distributor, and check which post the rotor arm is pointing at, and fit the plug lead for No1 to that post, then work round the lid in the firing order, and it should be right. Not unknown for people to remove the rotor arm to prevent theft, and then forgetting to refit it...
Oscar Lopez
oscarloco
Re: Engine Pictures
Just to be clear,Peter.N. wrote:What are spark plugs?
Oscar Lopez
daviemck2006
- x 485
Re: Engine Pictures
Looks too big for a glow plug [emoji12] [emoji83] [emoji23]
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
chinkostu
- x 30
Re: Engine Pictures
Is it not on a coil pack rather than a dizzy rich?
Most coil packs have 1 and 4 on one side and 3 4 on the other. Are all your leads the same length then?
Try:
The side with the multiplug as 1 and 4, then 2 goes next to 1 and 3 in the gap
Try:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
oscarloco
Re: Engine Pictures
chinkostu wrote:Is it not on a coil pack rather than a dizzy rich?
Try:
Thanks! Will check if it is that way. I suspect foul play as I had to fire one of my mechanics (I am in charge of my company's machines so I have 2 mechanics) and he was trying to get me to sell the car to him. He was really angry because I fired him (I had to, I discovered he was lazy as hell and was always getting in trouble with other people).
Anyway, thanks guys, you have been very helpful
Oscar Lopez
old-un77
Re: Engine Pictures
Purely, in jest, at a firm I worked for in the early 70's it was almost the norm for a rookie driver to be given this kind of test..........two leads swapped.........
That's strange? it was alright last night when I parked up!!
Bob
Bob
