Is this a wiring loom problem (206 1.4i 8v petrol)
mark21td
Unread post by mark21td »
Not been on for a while but need some help.
My daughters W plate 206 1.4 8v petrol is playing up, at first it was stalling on overrun, I took the ICV out, cleaned it and all was well.
Today it's been revving to 2k all the time, I checked the ICV (swapped for a known good one), the revving stopped but it was back to stalling and was missing until revs rise.
I know the coil pack can cause problems so I removed it (it's the black plug type) and also checked the plugs (NGK BKR6EZ) all look fine, good colour.
When I put it back together it now runs sweet.
So very time I disturb the wiring it either gets worse or runs well, with this in mind do you think I need to replace the engine bay loom, if so, where do I get one, I've looked on Ebay but nothing.
Any help will be great.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
spider
x 77
Re: Is this a wiring loom problem (206 1.4i 8v petrol)
Unread post by spider »
Are there any codes present ? I'd expect a wiring issue to be throwing codes about missing / invalid signal data.
Andy.
mark21td
I'm trying to get the codes read, but on a bank holiday weekend I coming with blanks.
Plus as it's running ok at present my daughter isn't keen on spending money :roll:
