Xantia 2.0 hdi lights
bill hughes
Unread post by bill hughes »
Hi all
I need to change a headlamp bulb on my Xantia, it was very simple on my 1.9tdi just unclip the cover, this one has a cover going right across the front panel with 4 bolts holding it in place, is it just a case of removing the bolts and panel or would that be too easy, any help would be appreciated.
Bill
VertVega
x 13
Re: Xantia 2.0 hdi lights
Unread post by VertVega »
Changing headlamp bulb was easy in my Xantia MK2. Left side (battery side) was easier which had more free space behind. With the right side I had to move/unclip a small hose to get better access.
I didn't remove the headlamp set for bulb replacement. There is a back lid/cover retained with a metal clip. After undoing the clip remove the back cover. Then remove the round rubber dust cover. Unclip the bulb holder and so on.
Changing a bulb in C5 II is more challenging :)
bill hughes
vertvego. thanks for your help, the piece of panel I referred to seems to bolt onto the top of the radiator so I presume you just unbolt it and remove the panel as there is no access otherwise
x 3282
Yes, that cover needs to come off.
bill hughes
Thanks Hell Razor I thought so, it says nothing in the owners manual or the Haynes book of.
bill hughes
Thanks for all your help, it was a very simple job once I had figured out which bits to remove, while I was at it I fitted 2 new high powered bulbs, waiting for night to come to see how much better they are. :-D
Stewart(oily)
x 35
Unread post by Stewart(oily) »
I use Philips vision plus in the Xantia dipped beams, standard wattage but much better illumination and dipped cutoff improved, the Xantia weak point IMO.
