I am getting a creaking noise from the gear lever when taking it out of 1st and 2nd gear. Just had a look in the Haynes manual and spotted the gear change lever pivot ball, do you think it could be this gone dry?
ZX creaking gear change
AndersDK
Yes [:)]
Citroen seems to use ball links in the gearchange to most models.
These links dry out over time - making for faster wear and funny creaks.
Unhook the link - rub down any rust on the ball - then use a fat sticky multi-purpose grease.
If the link unhooks TOO easy - then you better start looking for a spare - as a missing gearchange linkage in the middle of a roundabout is absolutely no fun [:D]
mijyou
AndersDK
VisaGTi16v
nooo anders theres far worse times. ie whilst doing a sprint event at Lotus cars test track 2 years ago in my visa. Drove 180 miles there. Start practise run get to 3rd corner and went for 3rd gear and hmm, ok, 4th? nope....rolled to a stop and bought out the red flag. Got towed back to the pits. Got it up in the air and precedded to fix using cable ties. Was fine for 3 more events like that
cable ties....the universal fixing method. Bloke i know broke the mounts that held his differential to his gearbox casing on his Fisher Fury at one. A couple of 2ton cable ties later and he drove home fine
Guru Meditation
mijyou
mijyou
AndersDK
