xantia alarm problems
ukmobileman
i have a P plate (97) xantia turbo diesel estate, the plip has 2 buttons and is a IR type, the alarm seems to be on when doors unlocked and off when locked!!! also there seems to be no key switch under bonnet where it should be (like on my 93 xantia t/d) it may have just fallen through panel and be wedged somewhere or not there at all! how can i reset alarm (i.e remove battery lead)or test it works correct ?
Dave Burns
ukmobileman
i had guessed switch had been discontined, also i tried the deadlocking with sencond button - thats when problem started the alarm seems out of sync with the central locking!!alarms sounds when i get in car after it been opened ! but if you lock it you can shake car and stick your hand through the open window and nothing goes off!
the lights indicators flash when alarm is armed/unarmed siren works etc - i just wondered if i disconnected battery if this will reset alarm or will it stay out of sync still?
Dave Burns
ukmobileman
