Hi all,
I have a 309 1.3 GE of '87 vintage and the rear axle is doing its usual creaky bit suggesting its on the way out! This being the 4th 309 1.3, I was wondering if it was possible to replace the entire rear axle assembly with one from a 1.9 GTI so that it toughens up the back end a bit, although I can forsee a problem with the disc/drum setup..... what other parts will I need?
While on the subject, how hard is it to replace the front struts and springs for GTI items as well? I had GTI springs on my GLX (309 number 3), and this eliminated the floaty disconnected feel, as well as clearing up the excessive roll problem, but with a fair amount of crashiness thrown in for compensation, I was hoping this would be reduced if i did the job properly!
Thanks,
Ricky.
309 rear axle
jackherer
the rear axle will bolt straight on but you need to replace the brake lines and add GTI rear compensators to get a balanced brake setup. I have heard of people using rear discs with drum lines but its not a good idea.
the front springs/dampers from a GTI are a straight swap, but to do the job properly you should also fit a GTI subframe, wishbones, and anti roll bar/droplinks.
you will need most of a 309GTI to do the conversion properly, so you might do better to just buy a GTI to start with, either as a parts donor or just to drive.
