Hard front end on xantia 2.0 vsx 1995
hayden2004
help
please
just replaced the front green spheres as the front is very hard ,,, and it still is what can it be ..it is the same if the sport or normel mode is pressed
please
AndersDK
Try the Citaerobics : http://citroenz.com/forum/viewtopic.php?t=42
- you're sure it's the correct spheres for your Xantia model front axle [?]
hayden2004
AndersDK
AndersDK
hayden2004
AndersDK
Ok hayden -
Now we're closing in on the problem -
What type/stock no is on the sphere box ?
What type/stock no is stamped on the spheres themselves ?
What type/stock no (GSF) is on the receipe ?
I'm trying to track down if someone mixed up the contents of the boxes - or if they handed you over the wrong sphere types.
BTW : does the suspension FEELS soft if you press down the front of car in normal height ?
alexx
Did you also replace middle sphere (I mean hydractive middle sphere, not accumulator sphere)? If you didn't, that's probably the reason why front end feels 'hard'. It's because of very small central bores in hydractive corner spheres. If you apply a constant force on the front end, it should, unlike non-hydractive models, sink very gradually, within several seconds, about 2 cm, and then height corrector will probably open and raise the car back.
Also, check that ride height is correct - approximately in the middle between lowest and highest position.
If all of above is ok, then you have a problem with hydractive system (probably poor electrical connection).
AndersDK
Tx Alex -
So you actually think that hayden's problem MAY not originally have been bad spheres ? - i.e. his old spheres MAY still be in good condition - the whole problem instead as you depicted ?
I think this is a very important information for hayden - as the route taken then with the suspension spheres could well be a dead end track.
BTW : I'm a bit surprised that hydractive corner spheres has such restricting orifice that instead the center sphere is providing soft feeling on the manual suspension jiggle test.
But that's simply the difference between academic & personal hands-on knowledge [:o)]
alexx
Well, it's hard to say what is the problem here, without enough information. But I think Hayden will be able to diagnose source of the problem this way and report the results.
Anyway, with engine running and car stationary, suspension should feel soft on manual bounce test, like in non-hydractive model. If you switch the engine off and close the doors, after half a minute ECU will switch to hard mode, and suspension will become hard. But, as I said - not completly - the car should dive under your weight, but very slowly.
Can someone tell me, how do hydractive middle spheres look like? Mr. Nastasic says that damper valves are in hydractive stifness regulators. So, are these spheres without dampers, do they look like accumulator spheres, or not ?
AndersDK
Alex -
From Gabor's techref Hydractive I chapter (page 27) :
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">1) A standard Citroen sphere base which fits a sphere
without a damper block. The sphere volume and pres-
sure differ for the front and rear, as well as according
to the model of the car;<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
As I'm confident about Gabor's knowledge, this means the center hydractive sphere in fact is a "standard accumulator" sphere, except for those differences mentioned.
Further on according to Gabor - no mention of damping elements are build in to the hydractive control valve block. These valves simply cuts in/out the center sphere.
Having this hydractive center sphere - with no damper element - connected in parallel with the corner spheres then means that extra damping must be provided on the corner spheres. This supports & explains your observations above.
hayden2004
