please help
i am attempting to repalce the rear wheel bearings
the haynes manual says to remove rear calliper i need to de pressurise the hydrailic system.
mine is a 98 xantia 1.9td estate and im not sure if its hydroactive or not because one says do it with the engine running and one says not.
any help much appreciated
mark
rear wheel bearings xantia
alexx
Engine should be running to depressurise suspension for '98 Xantia whether hydractive or not, because it has anti-sink fitted. If it's not hydractive, you can depressurise suspension after switching off the engine, until anti-sink valves close (it will probably take several minutes, maybe half an hour or so). After that, anti-sink valves will close and after moving lever to lowest position, the car won't sink, so suspension won't be depressurised.
blueboy2001
AndersDK
sheldon6
