Xsara Picasso problem
AdamC
Unread post by AdamC »
Hi there all hope everyone is well I had the throttle cable changed as it was over revving it was fine but now it keeps becoming loose so the car refuses to start until I move the clip to make it tighter I was wondering if I had a clip missing or something it currently has one metal clip in the grooves? Many thanks
Picasso is a 1.6 Petrol forgot to add.
x 94
Re: Xsara Picasso problem
Unread post by citronut »
hi and welcome
i cant see how a loose throttle cable could stop it starting,
there is a knack fitting the throttle cables as these days they come in kit form and to fit a hole barrage of cit/pug models,
maybe it has not been fitted correctly
were are you located
Regards, malcolm.
