suspension
michael1
suspension
Unread post by michael1 »
good afternoon,last night i was trying to unhitch a trailer and it was lifting the car up the hitch was stuck, so i thought i'd use the suspension to lower down the car (sorry it's a c5) could it be the fuse or have i band jacked it.what do i need do to get the main fuse board out.thanks
chinkostu
x 30
Re: suspension
Unread post by chinkostu »
I'm not sure what you mean, has it got stuck on low?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
Xantidote
x 5
Re: suspension
Unread post by Xantidote »
Concerning your original problem of unhitching the trailer, could you not try assisting the hitch to lift off the ball by setting up a jack just behind the hitch? Thinking that maybe it's just a bit tight? Did you have to jump on it to secure the hitch in the first place?
I'm assuming the trailer and car are on relatively level ground so that when you try lifting the hitch, the trailer's not making a bid for freedom?
Martin
1995 Xantia TDLX (deceased :( )
daviemck2006
x 496
Re: suspension
Unread post by daviemck2006 »
I often had problems taking the caravan off the c5. I found that I had to not touch the suspension, and if it started lifting the car, let the handbrake off on the car and rock it gently just by a light push and it came off no problem.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
michael1
Re: suspension
yes it's stuck in low,there was a jockey wheel on the trailer i was lifting it off with that i've been towing trailers for years but for some reson it wouldn't budge.
it's been raining here all day so i couldn't get out to try and see if it was the fuse.Do i just undo the nut at the front of the fuse box to get at the fuses underneath ?
chinkostu
x 30
Re: suspension
What happens when you try and stick it back in normal?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
michael1
Re: suspension
nothing the computer read that it's going up or down but the car dosn't move
chinkostu
x 30
Re: suspension
even if you leave it for a minute?
im not sure if the c5 is like the xantias that take a few minutes to rise
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
michael1
Re: suspension
i even tried to jack up the back
x 1980
Re: suspension
Unread post by Stickyfinger »
I think maybe the dog bone has come off when you used the jocky wheel, it should just clip back on if not broken.
michael1
Re: suspension
sticky where is the dog bone i'm a bit of a ficko when it come's to motors
x 1980
Re: suspension
Under the rear, look at the anti roll bar, ...on that is the connector that links it to the height corrector. The "dog bone" is the ball & socket jointed connector between the two. About 3 inches long
PS....it may be a good thing to do a forum search and read up on C5 suspension.
DO NOT GO UNDER a Citroen unless it is ON STANDS....NEVER trust a jack.....the Car WILL try and KILL YOU.
michael1
Re: suspension
cheers sticky the car will be the death of me 2 clutches in 13 months duel clutch went first and cracked the gear box week before xmas 2013 put second hand gear box in and clutch then without warning it went again week before xmas 2014 put a conversion clutch in now this i nearly done a bassall faulty on it :-)
michael1
Re: suspension
nope not the dog bone ;-(
x 1980
Re: suspension
There are "other" hings that can go wrong,
(FYI, when you jack a Citroen, place it in High position first, the jockey wheel was the jack in this case)
It may be the case the height corrector itself has seized.....spay it, wiggle it,repeat spray and clean, to get it moving. It is basically a rheostat, no need to force it, work it clean slowly then use spray light grease.
IF the pump fuse has blown, others will be better at helping to diagnose than me and will chime in I am sure.
