C5 Estate tailgate gremlins
wurlycorner
x 271
Unread post by wurlycorner »
A couple of days a week, the tailgate on my C5 decides to unlock itself sometimes, when I open the drivers door.
Most of the time it's ok.
Also the rear window doesn't unlock (hasn't done since I got the car). The button all feels in good nick etc but there's no action!
Any ideas on either of those?
Thanks :-D
Iain
CX DTR T2 Safari (silver)
x 5673
Re: C5 Estate tailgate gremlins
The glass lock will have a broken wire in the loom through the nearside hinge - common problem.
My tailgate used to unlock itself in very cold weather. Never did find a cure but probably related.
wurlycorner
x 271
Ah right, brilliant, thanks.
Before I go digging around, is it an internal break in the wire (and if so do how do I identify which wire it is) or does it tend to be an obvious external chaffing/break?
Iain
x 1996
Unread post by Stickyfinger »
With mine they were all horrid, it is more the insulation getting brittle with age and allowing in oxygen (thus the wire loosing flex) than a chaffing problem
x 5673
Mine was chafed. I had it repaired while having the aircon regassed, it broke again a couple of years later and I repaired and extended the wiring a bit but the following day my son smashed the tailgate in so got rid of it and bought a hatchback - regrettably. Estate much more convenient.
I'll see if I have any photo's left but don't hold your breath, could take some finding.
There is a write up on the testing and repair somewhere too.
Note that sometimes the switch can fail too.
x 5673
It is in this thread.
There is also a thread on the lock problem here.
wurlycorner
x 271
Thanks 8-)
Iain
