Saxo Stalling
Timmy69
Saxo Stalling
Unread post by Timmy69 »
Hi Guys
While out driving today my car stalled at Red Lights etc,the car starts straight way but next time i stop same again,it cuts out.Revs have been a bit low on tickover since it happened.
Any Idea's appreciated
Timmy
chinkostu
x 30
Re: Saxo Stalling
Unread post by chinkostu »
Which engine and year is it? Early SPI models used a stepper motor for idle which was prone to going wonky. MPI versions used an ICV which gums up sometimes causing odd issues such as it revving itself!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
Timmy69
Re: Saxo Stalling
chinkostu wrote:Which engine and year is it? Early SPI models used a stepper motor for idle which was prone to going wonky. MPI versions used an ICV which gums up sometimes causing odd issues such as it revving itself!
Hi
Its a X Reg 1.1 Forte Model..Is it expensive to repair and what do i need to do or get.
Timmy
chinkostu
x 30
Re: Saxo Stalling
Ooh a crossover. Post the reg and i'll get on servicebox in the morning and see which you'll need
Genuine bosch one for the spi models was £60ish when i last biught one. The newer one has a ICV that lots of models seem to use so theyre cheaper!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Timmy69
Re: Saxo Stalling
chinkostu wrote:Ooh a crossover. Post the reg and i'll get on servicebox in the morning and see which you'll need
X303 FET
chinkostu
x 30
Re: Saxo Stalling
Citroen part number 1920 AH
Best bet before spending anything is take the icv out, its on the back of the inlet manifold held in with two t20 torx screws. Unplug it and make sure the o ring is ok, give it a quick blast of carb cleaner to clear the crud off. On restart it might idle high, the suspected way to reset that is turning the ignition on for about 20 seconds, then off and repeat a few times. Works for me at least
On ebay theres this one
http://pages.ebay.com/link/?nav=item.vi ... 97&alt=web" onclick="window.open(this.href);return false;
I'll have to have a quick look to see if the 1.1 also uses the water temp sensor to set the idle speed. Is fast idle still ok at 1k?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Timmy69
Re: Saxo Stalling
Idle speed is at about 600 and drops below and stalls..Maybe a bit more when first started 1k maybe..The link you sent is for a 1.4...will it fit mine
chinkostu
x 30
Re: Saxo Stalling
Yea i'm 100% that they're all the same. At work so can properly check in about an hour if that helps?
servicebox lists two different ICV's for the 1.4, one only has a part number for saxo's, the other for a huge variety of 1.1 and 1.4 models
there is also this one on ebay
http://www.ebay.co.uk/itm/Idle-air-cont ... #vi-ilComp" onclick="window.open(this.href);return false;
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Timmy69
Re: Saxo Stalling
Thanks for the help Chinkostu..I had a similar problem with an Astra which was the EGR Valve..Should of known it was something like that.
Timmy
