peugeot 307sw 1.6hdi dead !!!!!!!!
mdl350
New User
Unread post by mdl350 »
I am hoping some one can help me I have a peugeot 307sw 1.6hdi 2004 we have just done a head gasket on but now will not start.
Before doing the head gasket could not get any communication with the car using three different diagnostic machines now
it won't start it says economy mode active on dash
heater controls windows and radio do not work but engine turns over fine but does not start have checked all fuses and charged the battery timming has been checked but still not working any ideas? Thanks.
x 94
Re: peugeot 307sw 1.6hdi dead !!!!!!!!
Unread post by citronut »
hi and welcome
have you had a DIS-LEXIA/PLANET plugged up it,below is a location map of FCF members who own a DIS-LEXIA/PLANET,
as this is the dealers diagnostic analyser,
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
i find with my DIS-LEXIA if the correct rp No. is not entered it will no always hand shake with all/some of the ECU's
were are you located
have you tried disconnecting and re/connecting the battery ( do not operate anything electrical on the car for a good minute on disconnecting and re/connecting the battery )
as the ECU's require a shut down period with no activity,
or maybe if the battery was disconnected for a prolonged period you have lost the immobaliser code
Regards, malcolm.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Gibbo Wirral, have you ever seen this? I've done yet another one today, the BSI completely loses its data, even the VIN is replaced by a line of "þþþþþþþþþþþþþþ"
So you start by adding in the VIN, then configuring the BSI, then re-learning the keys. 40 minutes once you've done a few.
An electronics tech suggested that a particular memory chip in the BSI may have a built in micro-battery that's nearly at the end of its service life (say, 10-15 years) and thus they become more unstable and likely to lose data if you flatten the car battery.
x 94
Re:
addo wrote: the BSI may have a built in micro-battery that's nearly at the end of its service life (say, 10-15 years) and thus they become more unstable and likely to lose data if you flatten the car battery.
a neighbor of mine used to have a Saab, the alarm went of when it felt like it, this was down to the alarm unit internal rechargeable battery dying,
Regards, malcolm.
Gibbo_Wirral
Re:
Unread post by Gibbo_Wirral »
addo wrote:Gibbo Wirral, have you ever seen this? I've done yet another one today, the BSI completely loses its data, even the VIN is replaced by a line of "þþþþþþþþþþþþþþ"
Not seen it personally but heard of it on the various forums and from another couple of diagnosers.
However, this seems to have happened after the car's been jump started a few times, so we just came to the conclusion that bad jumping procedure has fried the BSI.
As the BSI has re-writable components it is feasable that the flash memory is becoming weaker over time. I'm an IT engineer by trade and I see something similar a lot on older computers when the BIOS battery falls below a certain voltage - while the PC is connected to the mains its fine, but once disconnected the weak BIOS battery (even as high as around 2.75v) can't maintain the BIOS settings?
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
mdl350
New User
Hi guys thanks for the reply I have tried too do the bsi reset process but no joy. I am near bournemouth dorset.
Had another look today and checked I have no radio no heater controls no dip beam no wipers and no electric windows oh and non starting engine. I don't no if this sheds anymore light on it.
addo
x 95
It does seem like the situation I describe above. Anyone with smarts and Diagbox or Peugeot Planet can sort it. You absolutely need the four character secure code though, as the last stage is re-learning your keys.
Oh, one other detail, I had to go into "Forcing of the customer mode" before I could program keys.
x 94
what analyser/diagnostic device are being plugged up this car????
it really does need to go on a dealer type analiser ( Peugeot Planet/Diagbox,
i just looked at the Lexia location map in the link i posted near the top of this thread, and i see Sir MikeT is near you,
if you have not got/have access to one of these analysers, you could contact Mike and ask if he minds running his machine over your car,
hope you dont mind me offering your services Mr Mike [-o< [-o< :-D :wink:
Regards, malcolm.
x 1493
Being in eco mode will not stop it starting - but is the reason that none of the electrical accessories work. There are a number of reasons it might not want to start - but you need to get it on Diagbox so that you can check that you are getting cam / crank synch, that it can see the crank is rotating, and that you are getting sufficient rail pressure. This will then lead you to where to start looking. It is possible that you just haven't bled the diesel system well enough - try pumping the primer a lot with the ignition on, then leaving it for a few minutes, then giving it another pumping. You might just be lucky!
addo
x 95
The scenario I describe above, will stop it from starting, although it cranks.
x 1055
Re:
Unread post by wheeler »
I've seen this quite a few times, every time it has been related to the main battery, either when it has been disconnected without allowing the BSI to shut down properly or after attempting to jumpstart.
I've opened quite a few BSI's up but never seen anything on the board that looks like a battery, not that I'm an electronics expert mind.
With regards to the original post, did the car run before the head was removed ? Does it kick with a sniff of easy start ?
Peugeot_Russ
Unread post by Peugeot_Russ »
Just leave the car..abandon it. Bury it or sell the parts. I now see why PSA Peugeot Citroen is a failing car brand.
MikeT
x 232
Unread post by MikeT »
citronut wrote:hope you dont mind me offering your services Mr Mike [-o< [-o< :-D :wink:
Always happy to help others when I can. You're not volunteering me Malc, I did sign up to the lexia map.
