Hydractive ECU reset?
noxati11
Unread post by noxati11 »
Hello, it is probably stupid question, but is it possible do reset ECU of hydractive without Lexia? I've tried find something here, but couldn't find any direct answers.
(Hydractive light blinking up about 5 seconds after start)
Xantia 2.0 16V 112kW
Xantia V6 Activa
x 1460
Re: Hydractive ECU reset?
Unread post by xantia_v6 »
I think the answer is no. I believe that the blinking light feature is only found on very early cars (probably because the hydroactive ECU stores so many phantom faults).
x 8406
I believe you are correct Mike.. Only a Lexia, an ELIT and maybe some very high-end diagnostic systems like the Sykes ACR-4 will do the job...
noxati11
Thanks. I was afraid of it :(.
Xantia V6 Activa
