Having aquired a Xantia Hdi Exclusive Estate I'm now in the process of swapping the good bits from my Hatchback to the Estate as the plan is not to MOT the Hatchback when it expires in April and switch to the Estate. One of the jobs is to build one good drivers side front seat from the two. The estate base is the better as is the hatchback seat back. Has anyone swapped the complete back on an Exclusive leather seat, if so any helpful tips and pointers.
Rory
Xantia Seat Back Swap.
gadgetgricey
Re: Xantia Seat Back Swap.
Rory,
Don't think you can swap a hatchback seat back for an estate seat back.
Believe the seatbelts are within the back bit itself on the estate.
Not sure about the base, that might be OK.
Cheers
Dave
Cheers
Dave
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
citroenxm
- Fallen Hero
- x 70
Estate back seats are different to hatch. I beleve the mounting points are in different places to each other.. base and upper..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8306
Correct. The seat back clips to the C pillars are totally different...citroenxm wrote:Estate back seats are different to hatch. I beleve the mounting points are in different places to each other.. base and upper..
- x 1438
I think there might be a misunderstanding here... I reads that Rory is only talking about a front seat, which is the same in hatch and estate?
rory_perrett
Xantia_V6 you have it in one. Nothing wrong with the rear seats, it is the back of the driver's seat I want to swap. I was wondering if anyone knew what was in there. I'm hoping that the wiring for the side air bag is on a plug. Then there is the pump for the lumber support, is it fully containes within the seat back and again just a cable to be unplugged. And that's before the added complication of the motor. If ther eis a chance I'm going to bu**@r something up I will live with the seat out of the hatch. If I can do the swap the estate base with the hatch back will give me the best seat.
Northern_Mike
It appears some read "seat back swap" as "back seat swap"... oops.
Vorsprung berk Technik
- x 8306
rory_perrett
To answer my own question - it appears that the seat frame is a single welded unit so you can't fit the back of one seat onto the base of another.
