http://www.ebay.co.uk/itm/Mini-ELM327-V ... 5d4c431a94" onclick="window.open(this.href);return false;
theres an offer on google play for £3 credit when using paypal for the first time - meaning the app would be free
so would this actually work?
and ofc - would it work with my 97 synergie?
would this work?? *OBD2*
Harlequin
- x 23
Simon
Northern_Mike
Re: would this work?? *OBD2*
I don't believe it would work on a Synergie of that age as they're not OBD compliant.
Torque pro + cheap BT Adaptor does work well on compliant cars and Android phones though.
Vorsprung berk Technik
Harlequin
- x 23
BX
- x 19
The simple answer is no. What is more EOBD and OBD2 are very restricted in what information they give you. Most manufacturers permit you to see only the parameters and fault codes mandated by EU law. Common standards were opposed by manufacturers but imposed by the EU and USA. However the EU block exemption laws made it mandatory for manufacturers to make all their technical data available at a "reasonable" price. This and the common interface made it economical for diagnostic tool manufacturers to produce tools that go beyond EOBD relatively cheaply. More recently our oriental friends produce "genuine" manufacturers diagnostics such as IDS, diagbox and clip at very low prices. These tools have virtually main dealer functionality.
Some years ago I tried out some ELM interfaces. They are better than nothing on vehicles produced from about 2000 on, even on some that are not fully eobd compliant.
There are a number of hand held tools out there that will do basic diagnostics on your Synergies. Look at Foxwell, Autel and Seeley amongst others. The older model tools are now quite cheap.http://www.amazon.co.uk/Autel-MaxiScan- ... B00EN7JXGI
For the price the mini elm is worth a go provided you have a vehicle with the 16pin interface. The most you can loose is 7 pounds 24 pence.
Dave1987
is it cheap? Autel al419/Al519 works good than this and even cheaper
