hi newbie here
my son has a 2.0 hdi xsara picasso...reg... HN51 HBL....he recently changed the lift pump after the original failed....he switches the ignition on and off 6 times to prime the system...there are no visible fuel leaks and the seal on the fuel filter has been replaced..the car engine starts first time everytime but only runs for 40 seconds ..then dies...any help appreciated...
regards...
Barry
hdi..starts , runs stitops
Re: hdi..starts , runs stitops
Many be you are only getting positive feed to the fuel pump for 40 seconds ?
You should check this before going further, should be a simple enough test.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
hi thanks for the reply..could you please elaborate.....
Connect a meter to the lift pump power feeds. Time how long it stays live for. It might only be 40 seconds..
Vorsprung berk Technik
hi thanks for that...should the lift pump run all the time the engine is running...regards...barry
