[Synergie] Lower the rear suspension to level out the car?
kenbw2
(Donor 2017)
x 24
Unread post by kenbw2 »
The floor of my Synergie is tilted upwards at the back, and the wheel arches are at different heights on the front and back. I assume this is to compensate for extra weight in the back.
How easily, and safely could I lower the suspension on the back to the same as the front?
x 1240
Re: [Synergie] Lower the rear suspension to level out the ca
Unread post by Peter.N. »
I doubt you can if it has coil springs unless you can get some made, I used to deal with a firm called 'Wigan Road Springs' years ago when I was doing diesel conversions, don't know if they still exist.
x 94
Unread post by citronut »
look here
http://www.demon-tweeks.co.uk/performan ... n/synergie" onclick="window.open(this.href);return false;
or
http://www.dcperformance.co.uk/uprated/ ... ergie.html" onclick="window.open(this.href);return false;
these are just two results that came up on doing a gooooogly search on "citroen synergie suspension lowering kit"
Regards, malcolm.
kenbw2
(Donor 2017)
x 24
OK those look mighty expensive! I was more thinking to lower the existing stuff, but maybe that's not possible.
What about spring assisters on the front to raise that end?
x 1240
Didn't know they did stuff like that. Put a few bags of cement in the back.
x 94
Peter.N. wrote: Put a few bags of cement in the back.
or the mother in law :shock: #-o :-D :lol: :wink:
Regards, malcolm.
x 1240
:-D
